Hi, just to confirm, is the KL34H2160-62-8B stepper motor the longer version of the -42-8B motor ? I just want to make sure that I end up with the same shafting on each end of the dual shaft motor (12mm dia, etc)
I could not find a PDF spec for this motor showing the double shaft version, of course, I have not had that much coffee yet today.
BTW, thanks for offering this type of dual shaft motor set with the tight radial play specs, and symetric dual shafting - this is not so easy to find.
