586,060 active members*
4,152 visitors online*
    Jun 2021
    Closed servo connection
    Hi all,
    Am having trouble with connecting a servo driver,
    The driver has step, dir and enable + & -
    My controller has step plus and step minus
    Dir plus and dir minus, enable on,
    I have all conected up, its enabled and locked up, but wont move,
    Control signals seem to reach it, because as i move directions i see the 4.5 volts drop and rise on the pin outs
    Any help appreciated
    Jan 2018
    1516
    Re: Closed servo connection
    Could do with an image of your controller to see the connections or tell us which one it is so we can have a look at the pdf manual.
    Normally you have 5V (or 24V)+ power connection output going from controller going to all 3 + connections on the driver in parallel.
    So this one feed goes to PUL+, DIR+ & ENBL+, on ALL drives
    Then the - (negative) connections go from your controller outputs.
    So STEP- output to PUL-.
    DIR- output to DIR-
    Then ENABLE- output goes to ENBL- on ALL drives
    For Example: OUT1 to ENBL- on ALL drives
    OUT2 to X, PUL-
    OUT3 to X, DIR-
    5V+ out to ALL drives, PUL+, DIR+ & ENBL+.
    This is known as active low.
    It could be that your board has individual optocoupler type layout.
    In these cases, usually the + connections get daisy chained to the + power feed.
