Hi. I need a quote preferably from someone in the southern ontario area for some CNC machining work. this is one part of a couple similar parts and also some aluminum CNC turning could also be sent out for quote. This part is just cheap hot rolled steel that I normally buy as 2" x 1" flat bar.
The qty would be 20, 50, 100, 500 for pricing. I would probably take a lower qty as my first order and then increase it to either 100 or 500 pcs.
Thank you.
EDIT* I put the wrong file in the post, please read my post below with an explanation, Sorry
