586,070 active members*
3,517 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > harbor freight mini lathe wiring problem 7x10
    Question harbor freight mini lathe wiring problem 7x10
    Hello, I was given a harbor freight mini lathe being told the mother bored is bad.
    I checked the motherboard and all the switches for bad soldering ,burn components. took the mosfets off checked them. everything looked fine.
    but i bought a new bored and all new switches anyway. i wired them up the same way i got the lathe and still nothing. the red light on the on/off switch lights up but nothing moves the 1 and 2 terminals on the board show zero volts even when the switch is on and the nob is turned.
    maybe it was wired wrong from the last owner ? i cant find a good diagram that fit this bored perfectly.
    thank you
    Aug 2009
    1573
    Re: harbor freight mini lathe wiring problem 7x10
    ...is this your machine? on the last page is a wiring diagram
    thank you
  1. Is it still a HArbor Freight 7x10 lathe?
    By The_Dream_shed in forum Mini Lathe
    Last Post: 10-08-2023, 02:08 AM
  2. HARBOR FREIGHT 7X10 MINI LATHE CNC CONVERSION
    By ENEEL in forum Benchtop Machines
    Last Post: 09-29-2017, 12:36 AM
  3. Harbor Freight Precision Mini Lathe 7x10 Won't Run
    By yoyospirit in forum Maintenance DIY Discussion
    Last Post: 05-23-2014, 12:19 AM
  4. Harbor Freight 7x10 Lathe (#93212) Questions
    By Dman65 in forum Mini Lathe
    Last Post: 07-27-2009, 04:15 AM
