586,089 active members*
3,820 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > Programmable Coolant Nozzle-SpiderCool
Results 1 to 8 of 8
    I attended the Eastec trade show this year and was really impressed with a product called SpiderCool. It's a servo-controlled programmable coolant nozzle that delivers a high pressure stream right on the cutting point. Unlike P-cool, it's only competitor, SpiderCool can be programmed(without m-codes) to sweep the entire tool length to provide superior chip evacuation and cooling effect. I recently became a distributer in the MN area and am looking for customers interested in trying this option out- it can be added to existing coolant systems or can be installed with a higher pressure pump up to 1, 000psi. If anyone has questions or feedback to offer about an experience they've already had with SpiderCool I would love to converse. SpiderCool claims the system allows for faster feed rates(10%-35%), increases tool life dramatically, and eliminates manual coolant adjustments to reduce cycletimes, increase safety, and position a company to have better success with "lights-out" production. The basic system is around $2, 500 and pays for itself in 2 1/2 mo. with single shift operation. http://productionpal.googlepages/home or www.spidercool.com for more info.
    SpiderCool...
    bump...
    Jul 2005
    450
    Hi, firstly i would have to say im not really a potential customer, as 2,500$ coolant nozzles are way out of my league. That said i would be interested to know how the nozzle controller identify which tool has been loaded by the ATC without information from the machine controller?
    I saw in the marketing spiel that the machine uses a patented "intelligent interface", but you seem to have missed off any reference to the patent number.
    I wouldn't sell yourself short...even you are potential Spidercool user. $2, 500 would include a couple of additional options not included in the basic unit. You can purchase a STD unit for $1, 995 that will not sweep between two points. For $200 more you get the option- called Auto-Drill. The tool changer signals are monitored through existing sensors or via RS-232 if DPRNT feature is available on the control...
    Nov 2003
    98
    I am going to pass this info on too our engineering staff. I see a few machines which may benefit from something like this. Also you link above doesn't work.
    Bob
    SpiderCool Info...
    Sorry..the correct web site address is http://productionpal.googlepages.com/home
    If you have an e-mail address I can send you an electronic brochure...
    Thanks!
    Thanks for the interest....
    SpiderCool Pictures
    Pictures....
  1. Flexible Coolant nozzle
    By impact in forum Uncategorised MetalWorking Machines
    Last Post: 07-08-2009, 12:02 PM
  2. programmable coolant nozzle
    By jprobst in forum Haas Mills
    Last Post: 06-27-2008, 06:38 PM
  3. Haas programmable coolant unit problem
    By xs-speed in forum Haas Mills
    Last Post: 01-30-2008, 06:54 PM
  4. programmable coolant
    By pit202 in forum Haas Mills
    Last Post: 12-21-2006, 04:51 PM
  5. Floating upper nozzle
    By Klox in forum Waterjet General Topics
    Last Post: 05-10-2003, 12:49 PM
