586,096 active members*
3,446 visitors online*
Results 1 to 6 of 6
    Jun 2021
    4
    Unhappy Bridgeport Interact MKII TNC151
    Hello,
    I am trying to fix a Bridgeport Interact MKII with a TNC151 control that lost its machine parameters. I am currently using the machine parameters attached to this post. I have got the machine to work, however I am unable to change the speed of the spindle. It seems constant regardless of input value after entering a new value for the RPM after pressing "Tool Call"
    Am I doing something wrong? Has anyone else encountered this issue, if so how did you resolve it?
    Re: Bridgeport Interact MKII TNC151
    Quote Originally Posted by DCXXII View Post
    Hello,
    Hi did you get this going? does the speed change when you alter the spindle speed pot?
    Jun 2021
    4
    So far no. I am not the one who uses the CNC, the machine was working perfectly (i.e able to change speed by inputting desired speed), however stopped functioning properly in terms of spindle speed after machine parameters were lost during battery change.
    I opened the side to where the CRU card is located. In the maintenance manual, it says adjust the potentiometer (n max) on the CRU card to adjust the speed. I see marked lines by the previous user indicating where they are to be set. Would you still recommend adjusting the potentiometer, that being n max?
    I will adjust the potentiometer, but if that fails to show results, is there anything else I may try?
    Thank you in advance.
    Jun 2021
    4
    Update: Adjusting the manual speed override potentiometer between 80 to 120% has no effect on the speed of the spindle as well.
    1121
    https://www.cnczone.com/forums/bridg...r-lists-2.html
    There is a list for a similar machine in this thread
    Don't change it all over, but look for differences in relevant parameters
    1121
    look at parameters 62 63 78-89
  1. Bridgeport interact 1 MKII, parting out value
    By BrianP in forum Bridgeport / Hardinge Mills
    Last Post: 01-09-2015, 12:36 AM
  2. Bridgeport Interact 2 with Heidenhain TNC151 Control
    By lucylu in forum Bridgeport / Hardinge Mills
    Last Post: 12-27-2014, 10:36 PM
  3. Cheap CAM for Bridgeport Interact 1 MKII TNC155
    By Duncs in forum Uncategorised CAM Discussion
    Last Post: 09-03-2008, 10:08 AM
  4. Bridgeport Interact 1 MkII problem
    By sparsrus in forum Bridgeport / Hardinge Mills
    Last Post: 05-02-2006, 09:53 PM
