586,096 active members*
3,886 visitors online*
    Jan 2021
    6
    CNC dont Move on F code
    We buy a Bridgeport 5axis CNC milling MV 204 CU 15. I want some information and guidance about our machine. Would you please give me some help with CNC, for instance: User Manual, MP parameter, etc.?
    In addition, I have a problem. My machine doesn't move (Spindle rotates) when I run programs and code arrived at F code; in contrast, it normally works when I use FMAX code.
    Jan 2018
    1516
    Re: CNC dont Move on F code
    Quote Originally Posted by reza703 View Post
    Are you actually putting a feed rate number after the F or just putting a F only?
    Jan 2021
    6
    Yes, I put feed rate number after the F, for example, F2500
    Jan 2021
    6
    Quote Originally Posted by dazp1976 View Post
    CNC machine just works when using FMAX code instead of F2500
    Jan 2021
    6
    This problem has been solved. Finally, I found the issue. It was solved by making a change in MP3010.
    - - - Updated - - -
  1. DRO's move but the servos dont
    By rwskinner in forum Haas Lathes
    Last Post: 01-26-2021, 01:45 PM
  2. 30/40 machine axis dont move?
    By justleo7 in forum MetalWork Discussion
    Last Post: 03-31-2019, 01:13 PM
  3. Steppers dont move.
    By Varske in forum Mach Mill
    Last Post: 05-25-2017, 08:11 PM
  4. Replies: 7
    Last Post: 07-24-2015, 06:08 PM
  5. Y axis dont move
    By oneeye in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-25-2009, 06:16 PM
