586,115 active members*
3,435 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Wiring Help with DB25-1205 DQ542MA Nema 23 Motors Mach 3 Demo
Results 1 to 15 of 15
Threaded View
    Exclamation Wiring Help with DB25-1205 DQ542MA Nema 23 Motors Mach 3 Demo
    I'm a newbie to this stuff and this forum. so please bare with me and make explanation simple to understand for an old 62 year old fart
    I need some help with configuring my drivers and wiring for Mach3 Demo version
    This is what I use:
    Windows 7 pro with 32 Bit
    Parrallel port
    when I crank up Mach 3 and then go to device manager.
    I get a ? mark under drop down, so I applied a patch that I applied, but it still stays there ????????
    Wantai DB25 1205 Breakout Board
    Wantai stepper motor Model 57BYGH115-003 3.0 A 1.8 Deg/Step
    4 x DQ542MA Wantai drivers
    I'm using the Mach3 Demo version.
    I connected everything like Wantai motors told me.
    motors lock up when power is applied and it looks like mach 3 is going through its stages, but motors do not move
    Any help would be greatly appreciated
    I have tried to use directions for setting for mach 3, but I guess they may not be correct either
    I have a 5 volts power supply hooked up to MB , But when checking voltage it only reads 2.8 volts
    Attached Thumbnails Attached Thumbnails Image 1.jpg   Image 2.jpg   image 3.jpg   image 4.jpg
  1. Problem with Nema 34, DM860, DB25-1205 and Mach 3
    By Me109K4 in forum Stepper Motors / Drives
    Last Post: 02-13-2021, 12:20 PM
  2. Wiring NPN NC sensors to DB25-1205 BOB
    By millhouse_ in forum DIY CNC Router Table Machines
    Last Post: 12-05-2019, 02:42 PM
  3. Db25-1205
    By davidmccormick6 in forum DIY CNC Router Table Machines
    Last Post: 01-20-2018, 05:40 AM
  4. LinuxCNC, DQ542MA driver and DB25-1205 BOB
    By awes in forum LinuxCNC (formerly EMC2)
    Last Post: 11-23-2015, 02:18 PM
