The development team is pleased to announce version 1.9.2 of the RosettaCNC software downloadable from the download page:
https://rosettacnc.com/en/download-cnc.html
Changelog 1.9.2 vs 1.9.1
- Added Custom Values management for custom firmware.
- Added support of M109/M120 P100 Rr mode for multiple entry parameters dialog.
- Added new Tilting-Head A/B Kinematics management (see Board Settings -> Axes).
- Added Probe Analogic Input value visualization in Board Settings -> Digitalizer Panel.
- Added new Program Settings -> Compiler -> Macro sheet to define user macros path.
- Added new Top Toolbar Jog Mode button (see Program Settings -> Top Toolbar to set).
- Added CNC Board Warnings managements:
- Added new menu View -> Show Warnings.
- Added new menu View -> Show Warnings History.
- Enabled panel Warnings [ From Inputs ] in Program Settings -> Custom Alarms panel.
- Enabled panel Warnings [ From Modbus ] in Program Settings -> Custom Alarms panel.
- Improved DRO visualizations removing the Axes used as Gantry Slaves.
- Improved analogic input values visualizations.
- Improved CNC Board STOP -> RESUME management.
- Improved GCode language and compiler:
- Added support user macro path mode.
- Added #5121: Locked axes mask.
- Added #5139: Active user tool change procedure.
- Added #5427: Tool type used for compensation.
- Added new G10 L101 P
Vto set CNC internal parameters. - Added new M19: Spindle Orient (for supported firmware only).
- Added new M34: Add axis to the interpolated group.
- Added new M35: Remove axis from the interpolated group.
- Added new M36: Unclamp axis (for supported firmware only).
- Added new M37: Clamp axis (for supported firmware only).
- Added new named parameter #
. - Added new named parameter #
.- Increased number of dynamic commands usable in a G-Code Program/Macro/MDI.
- Changed named parameter #
to # . - Changed named parameter #
to # . - Improved G-Code compiling time when there are a lot of G38.x commands.
- Fixed Block Delete management.
- Fixed Macro encryption of large files.
- Improved 3D view management:
- Added Tilting-Head A/B management.
- Added view of Axes Arrows (new menu View -> Show Axes Arrows).
- Added view of Axis-driving vector when Rotary Guide for Axis [A|B|C] is shown.
- Added Zoom with CTRL+Mouse Y (normal) SHIFT+Mouse Y (reduced) to simplify trackbar use.
- Fixed Grid management with Tilting-Head Kinematics.
- Fixed Transparency of the Virtual Machine Geometries Edges.
- Fixed Transparency management when creating a new Virtual Machine.
- Fixed Virtual Machine Transparency value recovery when control software starts.
- Fixed Board Monitor -> Homing Correction Space visualization.
- Fixed G-Code Line in Execution & Last Line Executed visualization.
- Fixed Origin Mode to be always of type Custom with Rotary Axes for Table.
- Fixed Board Settings -> Axes -> Extra -> Cornering Acceleration Override default to 100%.
- Fixed Mouse issue when an M109/M120 dialog appears and the user is changing an OVR with the mouse.
- Fixed Control Software issue when pressing Tools Library OK button with CNC in SIMULATOR state.
- Fixed missing import of full data from settings.xml (CNC Board Settings) made with older versions.
- Fixed CNC dynamic info management to RESUME a stopped program also after a PC shutdown.
- Fixed visualization of Programmed Feed, Target Feed, Reference Feed in RUN/SIMULATOR state.
- Fixed Program Settings -> Access Level panel to avoid duplicate passwords between access levels.
- Fixed minor users reported issues.
- Added new firmware for Board-A/B 1.54:
- Aligned features with INTERFACE LEVEL 9.
- Added new Modbus Interface.
- Added new Tilting-Head A/B Kinematics.
- Added new commands for Orient Spindle.
- Added a new Jog Mode to move along the tool.
- Added new Order Code to control motor STEP/DIR up to 2Mhz.
- Added Homing Index management
- Added some new parameters to control new features.
- Disabled RETRACT management when a STOP occurs during a TOOL CHANGE.
- Improved G-Code BPS rate.
- Improved Interpolator Engine.
- Improved JOG with digital inputs to be more responsive.
- Changed Board-A/B OS to version 1.12.38.
A short video of new bevel-head support:
https://youtu.be/LH7sDliGtRY
https://youtu.be/UyubBwSsPWo
