586,036 active members*
3,718 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller & Computer Solutions > SMC5-5-N-N with Huanyang VFD - Detect rotation speed has reached
    Jun 2021
    Hello, after the M3 command, i would like the SMC5 wait that the spindle have reached is value before continuing. I saw a parameter on Spindle menu that say "wait for xx second before continue after M3 command" but i also saw that the pin UPF on the VFD can say to the SMC5 "i have reached the rotation speed, so you can continue"
    I plug UPF on the input 3 port of the SMC5 and run a program. The port 3 is off when i run the program, the spindle start turning, port 3 still be off and once the final speed reached, the port 3 is activated so that is perfect.
    the problem is i don't know where to set up "wait port 3 enable after the M3 command before continue the program" on the SMC5
    please if someone have an idea, it will be very welcome
    (ps: sorry for my english, i do my best so if it's not clear, feel free to tell me and i try to explain better)
    thanks a lot in advance
    Nov 2013
    Re: SMC5-5-N-N with Huanyang VFD - Detect rotation speed has reached
    Let us know if you figured it out, it can probably be done with gcode, read an input pin and use goto commands to loop with a delay and read the pin again
    15362
    Quote Originally Posted by inoujk View Post
    Using the wait in the control will be your simplest way to do it, so whatever you have for the spindle ramp up acceleration use that number in your control, to use the VFD Drive output you most likely would have to write a Macro for your control to use the VFD Drive output
    Mactec54
  1. MX4660 Speed Control for 2.2 KW huanyang vfd
    By Dekman in forum Leadshine
    Last Post: 06-27-2022, 10:10 PM
  2. Replies: 2
    Last Post: 03-06-2021, 05:37 AM
  3. Huanyang VFD speed control
    By morfeus80 in forum Spindles / VFD
    Last Post: 01-07-2019, 02:25 PM
  4. HUANYANG VFD ADJUST SPEED
    By instructor37 in forum Spindles / VFD
    Last Post: 02-14-2015, 12:28 AM
  5. down arrow and speed decrease huanyang vfd
    By curiosity22 in forum Phase Converters
    Last Post: 04-19-2014, 02:20 AM
