586,069 active members*
3,703 visitors online*
    stepper driver
    Hello, I need to replace my stepping motor driver cw1108, looks like they don't make them anymore, any ideas?
    Jan 2018
    1516
    Re: stepper driver
    This one?
    https://www.aliexpress.com/item/32544858351.html
    https://www.chinahao.com/product/524730259070/
    https://www.mpja.com/Stepper-Motor-D...fo/18727%20MS/
    CW1108 stepping Motor Driver - Chawing Electronics
    If the above is so, then...........
    It looks to me that any driver that works off 110-220vac such as the Leadshine DM2282 should be a compatible alternative:
    http://www.leadshine.com/uploadfile/down/dm2282d.pdf
    Just double check the specifications match yours first, but it looks like it does to me.
    Re: stepper driver
    You can use this one to replace it, KL-2283 8.3 A Digital Bipolar Stepper Motor Driver, AC 80-220VAC – 32 bit DSP Based
    https://www.automationtechnologiesin...ivers/kl-22083
  1. CL86T Driver Issues - Closed Loop Stepper Driver
    By Dreco in forum Stepper Motors / Drives
    Last Post: 08-22-2022, 10:08 AM
  2. Replies: 5
    Last Post: 08-01-2019, 08:25 PM
  3. stepper driver using h-bridge to analog servo driver
    By aztec in forum Servo Motors / Drives
    Last Post: 02-07-2016, 06:24 PM
  4. Replies: 7
    Last Post: 01-10-2015, 05:49 PM
  5. STEPPER DRIVER FAQ {Stepper/driver amp per phase match.
    By huios in forum Stepper Motors / Drives
    Last Post: 08-27-2006, 02:43 PM
