586,075 active members*
3,871 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Videos of my 'Almost Perfect' CNC Router with DIY ATC
Results 1 to 6 of 6
    Apr 2005
    629
    Greetings,
    I have put together some videos covering my DIY CNC Router which also has a DIY Automatic Tool Change system on it. This machine has been developed, modified, rebuilt, re-controlled, etc. over the last 15 years. I still have some more modifications planned in the future but for now I consider it "almost perfect". For those of you that are trying to decide on a control for your machine, I also explain why I abandoned the MACH3 software and switched to Centroid Acorn which has proven to be more reliable and "trustworthy". There is enough detail in the videos where you might also pick up some ideas for your machine. Here are the videos...
    Overview of the entire machine
    Demonstration video of Automatic Tool Change System https://youtu.be/qwkQbBZi40E
    Explanation of the magazine used in the Automatic Tool Change System https://youtu.be/jn7q5AzYjgo
    Explanation of the Tool length measuring and part height measuring sensors https://youtu.be/9FW6pWEcMcw
    Explanation of the Mechanical aspects of the Collet Nut Tightening / Loosening actuator https://youtu.be/FqJKw8ixR9c
    Explanation of the Electronics and Software aspects of the Collet Nut Tightening / Loosening actuator https://youtu.be/fDu7Rqzx27Y
    Thanks for taking a look.
    Chris D
    Jul 2014
    63
    Re: Videos of my 'Almost Perfect' CNC Router with DIY ATC
    Thanks for putting in all the work to make those videos!
    Sent from my SM-G781U1 using Tapatalk
    Apr 2005
    629
    Quote Originally Posted by Richmaple View Post
    You are very welcome Rich!
    Chris D
    Feb 2014
    23
    Haven't watched the videos, but props on the ATC... that sounds like a dream..
    Jul 2014
    63
    Quote Originally Posted by bwiab View Post
    I hadn't watched them either when I commented, since I know it's a ton of effort just to make the videos. But what he's done is a whole other level of engineering. The OP has a pneumatically actuated spindle wrench and a geared down collet nut tightener/loosener, all hooked up with limit switches and control logic, etc. It's mindblowing. Watch
    Apr 2005
    629
    It was, until I made it a reality :-), Thanks for stopping by.
    Chris D
  1. Where to start for DIY home router ATC
    By justCNCit in forum DIY CNC Router Table Machines
    Last Post: 09-25-2018, 01:02 PM
  2. My new router with DIY ISO30 ATC
    By kevincnc in forum CNC Wood Router Project Log
    Last Post: 04-09-2013, 06:57 PM
  3. DIY ATC automatic tool changer for cnc router.. Mythical or reality?
    By rodjava in forum DIY CNC Router Table Machines
    Last Post: 02-09-2013, 01:17 PM
  4. DIY router Atc
    By Big-tex in forum DIY CNC Router Table Machines
    Last Post: 01-04-2011, 02:34 PM
