586,043 active members*
3,625 visitors online*
    Dec 2017
    12
    Spindle cooling
    Building a 30”x48” router with a 2.2 kw spindle. Curious how cooling is done for this size of spindle, circulation pump came with spindle. How large of a reservoir will be required to keep,the spindle cool? I am planning to monitor the coolant temperature to the spindle, what temperatures should be seen and be safe.
    any insight is greatly appreciated.
    Jul 2014
    63
    Re: Spindle cooling
    I have a 2.2kw spindle and a pump circulating water from a 22quart commercial food storage container (this one https://amzn.to/3AlpLkH)
    It's hard to answer your question as the heat put out will be a matter of how hard your spindle is working which is also a function of what carrier frequency you have your vfd set to, the ambient temp, etc etc etc). That said if you have enough water, you can basically run all day as water has such a high heat capacity before the water gets even warm to the touch.
    I don't know what temp would be the max temp before it stops effectively cooking the spindle. And even that would be a factor of how fast your water flow is. You see what I'm getting at... Just go for it and you likely won't have to worry about it
    Sent from my SM-G781U1 using Tapatalk
    Nov 2008
    642
    Re: Spindle cooling
    I have a 1.5kw spindle (not used for production) and have a 7 L tank. The fan comes on at 20C. I don’t think spindles generate a lot of heat, you just need to draw what heat they generate out.
    Jan 2007
    626
    Re: Spindle cooling
    Quote Originally Posted by Dean448 View Post
    What Dean said.
    Sent from my SM-G970F using Tapatalk
    Dec 2017
    12
    Re: Spindle cooling
    Thanks for the feedback, seems a reasonable starting point is a 5 gallon container and monitor. I may have been overthinking this
    thanks
    Steve
  1. China Spindle Cooling
    By Lilithet in forum DIY CNC Router Table Machines
    Last Post: 03-18-2019, 07:57 AM
  2. Spindle cooling need help
    By Elektryk in forum Spindles / VFD
    Last Post: 06-27-2014, 06:40 AM
  3. 2.2 kw spindle cooling
    By Jerry In Maine in forum DIY CNC Router Table Machines
    Last Post: 04-13-2013, 11:32 PM
  4. spindle cooling
    By alan collins in forum Australia, New Zealand Club House
    Last Post: 03-10-2012, 11:26 AM
  5. Spindle cooling with PC Liquid cooling system
    By enforcer in forum DIY CNC Router Table Machines
    Last Post: 02-07-2012, 09:02 PM
