586,121 active members*
3,415 visitors online*
Results 1 to 2 of 2
    Jan 2021
    6
    Siemens 808DA - Read-in enable missing
    Hi all,
    Out of the blue during a tool change I received “read-in enable missing” error.
    Basically the atc swapped from one tool but when it grabs the next one it engages the pull stud and then doesn’t move, the atc fails to move back, and doesn’t register that it has a tool in the spindle.
    A google search seems to show that it may be a sensor not reading properly.
    I did a startup reset which not only didn’t fix the problem, but now my spindle doesn’t orient to the current angle for a tool change, it now orientates to 101° instead of 174°.
    Any help is hugely appreciated.
    Cheers
    Sep 2009
    99
    Re: Siemens 808DA - Read-in enable missing
    In the 808DA you can see the PLC ladder in real time (Under the system settings menus). You can check and see which sensors are working and which are not.
    It is likely there is some sensor which has gone loose or stopped working which is causing this issue.
    As for spindle orientation, that would usually be a parameter which might have changed. Is your spindle a belt drive or direct drive? If its a belt drive, check if your belt is slipping. If your spindle has a gear ratio, there would be a proximity for reference which might be out of position.
    If its a direct drive, check if either side of the spindle to motor coupling has gone loose, although I would assume this being unlikely..
    Best regards
    Jaideep
  1. axis enable missing / DB35 DBX2.1 is missing
    By Max2000 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 06-13-2019, 06:54 AM
  2. read/punch missing in fanuc oi mate td
    By sina_nej in forum Fanuc
    Last Post: 08-15-2018, 12:46 AM
  3. SIEMENS ACRAMATIC 2100 KEYBOARD TOUCHSCREEN MISSING
    By abadade in forum Cincinnati CNC
    Last Post: 09-15-2017, 02:46 PM
  4. Alarm 6106 Missing data block on Siemens Hitrol-805
    By unitedmachining in forum SIEMENS -> GENERAL
    Last Post: 07-04-2013, 01:18 AM
