586,051 active members*
3,644 visitors online*
    Bridgeport EZ Path
    I have a bridgeport machine that when you power it up, the table will move all the way to one side & you have to power it down to stop it. What could the issue be?
    Aug 2009
    1573
    Re: Bridgeport EZ Path
    assuming you have DC Servo Amp's if, Yes what Model number Amp's?...Tach wires backwards...Motor wires backwards...has someone been doing any wiring when the problem started? Has the machine ever run correctly?
    It is DC and no one has worked on it. It is a machine that seldom gets used.
    Quote Originally Posted by wwooley316 View Post
    A good place to start is to probe the connection to the relevant servo and see if it's shorted to the DC bus.
    Jun 2004
    55
    hi, check your limit switches, i had an eztrak that did the same thing and i found out that i had a limit switch that was stuck .
  1. Bridgeport/Romi EZ Path 2 SD
    By JRN in forum Bridgeport / Romi Lathes
    Last Post: 08-14-2020, 02:42 PM
  2. Romi/Bridgeport EZ-Path Lathe serial transfer using EZ-Path Utilities
    By Moscow in forum Bridgeport / Romi Lathes
    Last Post: 06-04-2017, 04:37 AM
  3. Bridgeport EZ Path
    By elsie215 in forum Bridgeport / Romi Lathes
    Last Post: 01-07-2011, 10:04 PM
  4. bridgeport ez path lathe
    By sempe0 in forum Want To Buy...Need help!
    Last Post: 03-11-2010, 06:01 PM
