586,339 active members*
3,898 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > KIA VMC V60 Fanuc (18M)... All Parameters are lost
    May 2018
    I have a problem with my KIA VMC V60, all parameters have been cleared accidently, including (PMC parameters, Keep relays, CNC parameters, Ladder, Custom macros) after contacting with manufacturer technical support.
    they sent me the following:
    - CNC parameters
    - PC
    Parameters including (Timers, Counter data, Spindle speed data, Manual feed data, ATC, .....)
    - Pitch Error compensation
    and told me that are all they have for this machine, and send me PLC file for another machine (*.MEM) which I couldn't deal with, I hope if this file contains the ladder, and other missed stuff, even if there's slight difference, cause I have in the machine manuals the ladder diagram that might allow me to compare and get my machine working again.
    Please if you have any idea, help me!
    Re: KIA VMC V60 Fanuc (18M)... All Parameters are lost
    Your ladder isn't lost. Once you loaded in the CNC parameters then your ladder will pop up again. Fanuc has several ladder types for that model of CNC and once you set the option bit for the correct PMC type that is in your machine then it will be able to be displayed.
    May 2018
    [QUOTE=drdos;2460356]Your ladder isn't lost. Once you loaded in the CNC parameters then your ladder will pop up again. Fanuc has several ladder types for that model of CNC and once you set the option bit for the correct PMC type that is in your machine then it will be able to be
    May 2018
    Quote Originally Posted by drdos View Post
    I already have uploaded the parameters but there's nothing in the ladder diagram.
  1. Replies: 1
    Last Post: 01-07-2021, 07:39 PM
  2. Replies: 2
    Last Post: 10-03-2015, 10:31 AM
  3. Replies: 16
    Last Post: 01-10-2014, 09:24 PM
  4. TOOL SETTINGS FOR MY FANUC 18M VMC
    By PICMAN in forum Fanuc
    Last Post: 12-02-2007, 12:59 PM
