Hello all, i am testing my step motor controller. How come the shaft doesn't move? but i am hearing the noise that motor makes.
My first guess would be wires to the wrong coil(s) on the motor or a loose connection. Is it a 6 wire motor?
Have you done any voltage checks?
its 8 wire motor, running off from 24v power supply. i've check everything, they all connected. i'll do a triple check just to make sure.
Have you checked the current of your controller? Maybe the motor uses up more current than the power supply provides
-Please check out my webiste-
http://www.teilhardo.com
Try reducing the speed. It's loosing all of the steps.
Eric
I wish it wouldn't crash.
How can i do that? I'm using turbocncOriginally posted by balsaman
Eric
