586,069 active members*
3,346 visitors online*
    Esa Tria 7500 PLC.
    Morbidelli Author 504 ( 1997 3-ax + vector ax )
    I have got out off the blue the next error in red capitals: 0000 PLC BLOCK.
    I contacted SCM in the netherlands They said that it was a problem with the backup .( New back-up battery for less than a year ?)
    New battery, program and parameters loaded.
    After switching on the machine the x-ax started uncontrolled moving without touching the calibration button.
    Has anyone a suggesting what this could be, ore what to do?
    ( an other Esa Tria 7500PLC is welcome)
    Feb 2006
    19
    Re: Esa Tria 7500 PLC.
    Hi there,
    I know I'm a little late but have you looked at the X axis drive?. When the machine is in Estop, and you push the x axis by hand, does the position count correctly on the screen? Have you checked the cables to the x-axis. They pass through the drag chain and could be damaged
    Let me know how you get on
    Louis
    Sep 2019
    7
    Did you get it working with the x-axis?
    I have a Author 504 with 3-axis + vector. My machine started to "jump" uncontrollable on the x-axis. The serviceman managed to locate the problem to the analog controlcard. The voltage was way high on the output pins. After a switch to a new one it's working like a charm!
    Regards
    KJ
  1. AUTHOR 503RAPID TRIA 7500
    By Luisako in forum Controller & Computer Solutions
    Last Post: 03-10-2021, 12:00 PM
  2. Tria 7500
    By num1040 in forum CNC Machining Centers
    Last Post: 11-30-2019, 03:12 PM
  3. Tria 7500 Morbideli 510
    By trbale in forum Controller & Computer Solutions
    Last Post: 04-01-2017, 11:51 AM
  4. Esa Tria 5500
    By niki2014 in forum Controller & Computer Solutions
    Last Post: 03-23-2015, 07:39 PM
  5. TRIA 7500 software missing
    By pablogvivo in forum Controller & Computer Solutions
    Last Post: 01-07-2014, 09:45 AM
