586,069 active members*
3,247 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller & Computer Solutions > Controller for 7 x 9 feet (2 x 2.5m) FAST drawing machine
Results 1 to 2 of 2
    Nov 2015
    Hello
    I'm building a 7 x 9 feet (2 x 2.5m) "drawing machine". Essentially a very light duty belt driven CNC with a pen instead of a router. I need it to be FAST (2-3 feet / second)
    For this kind of machines, I have used in the past OpenBuilds BlackBox, but this time I want to use either closed loop steppers or servos for which the BlackBox doesn't work. The reason is that the machine will have to run nonstop for days and any missed step will destroy the final drawing.
    Can anybody recommend a setup consisting of a closed loop or servo + controller that accepts G-code?
    Also: The longest wires to the motors will be 5m - 16 feet. Can that be an issue?
    Thanks!
    Nov 2013
    4373
    Re: Controller for 7 x 9 feet (2 x 2.5m) FAST drawing machine
    if you are using AC servos, which are really the way to go, then they accept Step/Direction input just like an open loop stepper. The servo drive does the feedback
    and ensures that the servo stays within a very small (programmable) error between commanded and actual position.
    I'm guessing therefore that your existing Black Box, assuming it is Step/Dir output, will work for servos just as well.
    I use Mach4 and have done for some years. It digests Gcode, then produces numeric data for a motion controller board (Ethernet SmoothStepper) which in turn signal a breakout board
    which allow you to hook up to real world servos/ limit switches etc. I use Delta B2 series servos (160,000 count/rev encoder), and they spin up to 5000 rpm no trouble.
    Craig
  1. auto-feeding machine 4*8 feet
    By Roctech-Mercy in forum Roctech CNC Routers
    Last Post: 06-29-2020, 03:26 AM
  2. CNC plasma cutter 10 feet by 5 feet
    By phmadeira in forum DIY CNC Router Table Machines
    Last Post: 04-12-2017, 10:36 PM
  3. Proper feet for my machine
    By turbo2ltr in forum Uncategorised MetalWorking Machines
    Last Post: 09-30-2014, 04:42 PM
  4. Machine feet - Buy or make your own?
    By murak in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 10-03-2013, 07:50 AM
  5. reduce rapid feet to set up machine
    By specky in forum Fanuc
    Last Post: 08-16-2011, 11:01 AM
