586,069 active members*
3,757 visitors online*
    Dec 2006
    310
    FANUC Controller Oi-Mate-TD
    Dear Experts
    We are facing an issue of Display not getting ON in FANUC Controller Oi-Mate-TD, Type: A02B-0321-B530 .
    Found 24VDC is OK at input connector CP1 to Controller and “8” appearing on CNC .
    · We have tried by disconnecting all connectors except CP1, also
    · We have tried switching on by pressing soft keys 1&2 and 1&7 together Still same issue of display not getting on
    · Fans are in working state
    Request for advice
    Regards
    Dec 2009
    953
    Re: FANUC Controller Oi-Mate-TD
    If the "8" is solid:
    "State where the cpu is not started after power is turned on"
    -the mainboard may be faulty
    Back up need it if you wanna mess with the mainboard,otherwise will be lost due to manipulating the FROM/SRAM module.
    Better call Fanuc India for this kind of job.
    Good luck
  1. FANUC Oi Mate TC controller Threading problem
    By rapnumeric in forum CNC Machine Related Electronics
    Last Post: 02-23-2020, 09:55 PM
  2. Replies: 1
    Last Post: 03-06-2015, 06:26 PM
  3. Fanuc OM mate with OMC controller
    By splicer in forum Fanuc
    Last Post: 02-22-2013, 06:16 PM
  4. Replies: 8
    Last Post: 06-03-2009, 02:14 PM
  5. Replies: 1
    Last Post: 10-19-2003, 02:34 AM
