Trying to find solenoid valve for a gear shift issue on my Kuraki KBT-11.
Thank You in advance.
What is wrong with the solenoid?
Have you contacted a local hydraulic supply house, usually they are able to sub a replacement.
Albert E.
Three valves on the block in the picture. Two of them bi-directional. Activate it with screw driver to see what it is responsible for.
Make sure it is safe to activate in advance.
Albert E.
1. Sure no.
2. Disconnect electrical connector and activate with screw driver then. Would be safe.
I saw it happen plenty of times with mechanical maintenance service teams.
One of the reasons I always spec'ed in DC coils for new projects, it can't happen with DC.:idea:
Albert E.
