Hello,
Can anyone answer? Not even PlanetCNC?
Quote Originally Posted by leomonti View Post
I have a problem with the TNG software. After the migration from USB to TNG, with a MK3 / 4 controller, with the same motors and the same drivers, the motors stall after a certain speed. I don't know if there is some setting to change. I haven't changed any of the driver parameters. I tried to change "step width" (default is 12ms) in the program settings, but it doesn't change anything. Using an MK2 card and the old software, always with the same motors and the same drivers, the problem is not there. Has anyone noticed the same problem and can you suggest a change in the parameters that I can solve?
Thanks in advance
