ZIPSNIPE: Thanks for the wake up Call!!
The rails & trucks were attached to the base casting.
The Y axis Truck mounting plate was sized and the holes were drilled
to retain the blocks.
Was unable to mount the lead screw nut. The nuts received from SDP – SI on the first order were easily installed . The nuts received on the second order were No Good.
Was able to find a NEW Brubaker 5/8 – 10 tap on Ebay, expect to receive it this week.
If I can’t correct the existing nuts, I can machine some DELRIN rod I have here to keep the project moving!
