586,068 active members*
3,954 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Third party servo drive for old yasnac control
    Aug 2013
    9
    Hi, we got a old Matsuura with yasnac MX3, we had a damaged drive recently,so i checked manuals and the control signals for these drives seems to be pretty standard, Enable, Fault, Servo ready, +-10v analog and encoder feedback to the controller.
    I retrofited another matsuura before using the original servo drives and motors, i used Linux CNC and it worked like a charm but i wonder if it is possible to install a cheaper and newer drive like those from AMC as a replacement for the old drive, and keep the old MX3.
    Perhaps there are some tweaks to do for the 50 pin honda connector, i see it possible.
    Has anyone tried it?
    Yaskawa drive model is CACR SR15 SB1AF, the servo motor is AC driven with 9.7A rated Amps.
    Encoder has A B Z U V W outputs, 6000ppr i think.
    Regards
    Meth
    Sep 2010
    1765
    Re: Third party servo drive for old yasnac control
    If indeed the encoder output is generic TTL 5V ABZ encoder, then you can use a Kollmorgen AKD drive to replace it. The AKD will auto phase the feedback to the motor. Cost depends on current & voltage rating of your motor. We can supply you a 12amp AKD model good for 120/230V or one good for 230/460V (a tad more expensive) and help you make it work - AS LONG AS your encoder is standard incremental model. In quote for drive I could include a small amount to teamview into your hooked up drive and commission it with you over the internet.
  1. I need advice on servo drive control and software
    By DoubleSun in forum USA Club House
    Last Post: 09-02-2017, 01:42 PM
  2. For all Yasnac J300 Controllers There is third party memory upgrade option!
    By drutort in forum Uncategorised MetalWorking Machines
    Last Post: 09-23-2015, 04:17 PM
  3. Replies: 0
    Last Post: 05-24-2014, 02:23 PM
  4. Third party AC servo amps
    By billb95 in forum Servo Motors / Drives
    Last Post: 09-18-2012, 11:46 AM
  5. Replies: 4
    Last Post: 02-15-2012, 04:52 PM
