586,067 active members*
5,288 visitors online*
    Jan 2009
    55
    LNC-8 Drive belt
    All,
    The parts book list the drive belt as a 12PK1445 Rib Ace. What is on the machine is a 7PK1445 and a 5PK1445.
    Should I go with the two belts, as the factory had it, or the wider single belt? (which would avoid the chance of slightly differing lengths on the two belt system)
    I've owned the machine since it rolled off the Okuma line...so it came with 2 belts.
    Mar 2009
    1982
    Re: LNC-8 Drive belt
    both of course
    Jan 2009
    55
    Any information as to changing the spindle encoder timing belt? LNC-8
    Mar 2009
    1982
    Check if it is needed. Normally the encoder belt is not heavy loaded. Evaluate wearing and decide.
  1. Replies: 1
    Last Post: 10-20-2018, 04:27 AM
  2. I.H. Belt drive conversion spindle drive sleeve gear
    By Roadstercycle in forum RF-45 Clone Mill
    Last Post: 04-23-2018, 12:43 AM
  3. Which is good drive system belt drive or gear druve
    By M.Abid in forum Excitech routers
    Last Post: 12-14-2014, 04:13 PM
  4. Direct Drive Vs Belt Drive for a Mill/Drill Retrofit?
    By pfeist in forum Uncategorised MetalWorking Machines
    Last Post: 02-13-2012, 09:12 AM
  5. Need Sherline Belt & qestion on X2 Belt Drive?
    By Oldboy in forum Benchtop Machines
    Last Post: 03-06-2008, 07:42 AM
