586,051 active members*
3,644 visitors online*
    Jul 2021
    Pin order NE556
    The pin sequence of the patch NE556. I can't find any marks on the chip. The NE556 I wrote on the picture is the English direction on it.
    Reference: https://www.utmel.com/components/ne5...tasheet?id=156
    Attached Thumbnails Attached Thumbnails QQ截图20210721171028.jpg   QQ截图20210721171038.jpg
    Mar 2009
    1982
    Re: Pin order NE556 The pin sequence of the patch NE556. I can't find any marks on th
    hold the chip bottom down, one row of pins bottom one row top. If you reed markings on the top normally - upside up, the bottom leftmost pin is 1. The top rightmost pin is the next after last in the bottom row.Click image for larger version.
