586,106 active members*
2,966 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > seeking sbc centurion 5 M326 v5.5
    Feb 2006
    49
    My Centurion 5 controller will not boot and I suspect the sbc may be the culprit and would like to buy a replacement or find someone that can repair mine. It was installed on a Standard Modern lathe in 1995 and dies a few days ago. The board model number is M326 V5.5. I attached some pics. One shows a trace that is dark and looks corroded and may be damaged. I would appreciate any suggestions on solving this problem.
    Attachment 467142Attachment 467144Attachment 467146
    Doug
    Mar 2017
    63
    Re: seeking sbc centurion 5 M326 v5.5
    Solder a wire to bypass the corroded part of the trace
    Sent from my SM-N960U using Tapatalk
  1. Replies: 22
    Last Post: 07-23-2021, 09:50 AM
  2. Milltronics Centurion 6 SBC Issue with Display
    By HuxRacing in forum Milltronics
    Last Post: 03-17-2021, 11:20 PM
  3. Centurion V diy SBC upgrade
    By Fran_k in forum Milltronics
    Last Post: 04-19-2015, 05:22 PM
  4. SBC Cycle's Pineapple
    By Ed from NY in forum BobCad-Cam
    Last Post: 08-19-2009, 09:07 PM
  5. Centurion 5 vs. Centurion 6 and validation codes
    By Turbo VW in forum Milltronics
    Last Post: 02-11-2007, 09:35 PM
