586,655 active members*
3,474 visitors online*
IndustryArena Forum > CAD Software > Uncategorised CAD Discussion > Determining correct wires from stepper motor
    Mar 2016
    46
    Is it possible to determine the wires from stepper motor A+ A- and B+ B- using a multimeter ? If so HOW ! thanks
    Nov 2013
    4442
    Re: Determining correct wires from stepper motor
    there will be a low resistance, several Ohms or less between A+ and A-, and also between B+ and B-, but open circuit between any A and any B.
    As for the difference between + or -...who cares. Just wire it up and then swap just one winding if the stepper is going in the wrong direction.
    Craig
  1. Determining stepper motor wiring
    By getrolfed in forum Stepper Motors / Drives
    Last Post: 02-20-2012, 11:23 PM
  2. stepper motor with 8 wires
    By genije in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-31-2008, 09:18 PM
  3. stepper motor with 4 wires
    By shauttra in forum Stepper Motors / Drives
    Last Post: 04-03-2008, 11:07 PM
  4. Need help determining coil connection wires
    By mulligan in forum Stepper Motors / Drives
    Last Post: 03-02-2008, 05:53 PM
