586,410 active members*
3,356 visitors online*
Results 1 to 9 of 9
    Jul 2021
    13
    Finishing mistery
    I am trying to figure out why shorter endmills are giving me MORE tool marks than longer ones. Anyone ever seen this? Cutting wax with very small bits, and just looking for any kind of theory that I could test with. Again, all factors the same, but shorter bits give worse finish.
    Aug 2008
    406
    Re: Finishing mistery
    You holding all the tools the same way .You talking about the floor or wall finish ?
    Apr 2004
    5741
    Maybe your longer bits are sharper.
    Andrew Werby
    Website
    Jul 2021
    13
    Quote Originally Posted by gabedrummin View Post
    Yep... Using an ATC. Tools from the same supplier, tried multiples of each, all brand new.
    I am seeing it on the slopes and floors, not walls. A straight line in the floor looks like an open bracket. The direction the bracket faces looks to depend on the direction of cut. G40 is set, G41 not used.
    15362
    Quote Originally Posted by Alphastar View Post
    G40 and G41 G42 are not needed that is for cutter compensation, would have nothing to do with how the surface finish looks even if it was being used
    G40 is cutter comp cancel
    G41 is for cutter compensation left
    G42 is for cutter compensation right
    Mactec54
    Jul 2021
    13
    Right... I merely brought it up because I wanted to show that it was turned off. Because if not, you would get that exact problem.
    Anyway, everything is opposite. Long tools are giving me less toolmarks. Toolmarks are perpendicular to cutting direction. For example, a horizontal pass is giving me vertical lines, and a 45 degree parallel pass is giving me lines at 135 degrees.
    Nothing makes sense.
    Mar 2009
    1982
    what if you increase / reduce the spindle rev ?
    Jan 2018
    1516
    Tool Helix?.
    A couple of my tools leave a horizontal line all around the side of a part when doing a contour finish pass.
    Unexplaned. Tools looked fine
    15362
    No Cutter Compensation would have nothing to do with finish on the part
    Anyway, everything is opposite. Long tools are giving me less toolmarks. Toolmarks are perpendicular to cutting direction. For example, a horizontal pass is giving me vertical lines, and a 45 degree parallel pass is giving me lines at 135 degrees. Nothing makes sense.[/QUOTE]
    Can you post so photos of the cuts
    Mactec54
  1. Doosan Puma 2100Y tapping mistery
    By torentino in forum Fanuc
    Last Post: 04-18-2020, 03:48 PM
  2. Replies: 1
    Last Post: 02-29-2016, 01:26 AM
  3. The Greatest Mistery of Chinese Lasers...
    By amp79 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-23-2013, 10:16 PM
  4. Soba (Shoba) 4'' rotary table problem/mistery
    By simonfilm in forum Uncategorised MetalWorking Machines
    Last Post: 10-19-2011, 08:10 PM
  5. Finishing
    By jrobson in forum Surfcam
    Last Post: 03-06-2008, 10:59 AM
