586,116 active members*
3,519 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > VS40 TOOL CAROUSEL HOME POSITION
    May 2008
    11
    This mill has Fanuc 18M control. The battery was replaced on the tool carousel servo drive unit. We need a procedure to move the carousel in small increments to establish correct tool alignment and then toggle the 1815 parameter.
    Does anyone have this procedure?
    Feb 2015
    82
    Re: VS40 TOOL CAROUSEL HOME POSITION
    Did you get this fixed?
    Oct 2019
    17
    It's a Seicos 18M and a Fanuc 18iMa
    K000.7 is magazine handle select.
    Making this keep relay allows the MPG to operate the tool chain when placed in the 4th axis.
  1. Tool Offset home position
    By Mooser in forum Tormach PathPilot™
    Last Post: 06-24-2020, 03:49 AM
  2. Need help with Correct tool carousel position in tool library
    By supraman in forum Uncategorised CAD Discussion
    Last Post: 06-07-2016, 12:01 AM
  3. Fanuc OM tool carousel position
    By michaelpaul13 in forum Fanuc
    Last Post: 09-06-2015, 09:33 PM
  4. Tool Post Home Position
    By joseph10s in forum Fanuc
    Last Post: 07-05-2011, 08:33 PM
  5. tool carousel position problem
    By Greg 24 in forum Haas Mills
    Last Post: 10-19-2009, 09:44 PM
