586,069 active members*
3,445 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > AL-4824-120-FLX - 120W CO2 - Controller Retrofit and Laser repair ?
    Oct 2010
    46
    Hello guys,
    Recently got a 120W CO2 laser, 48"x24" laser machine won in an industrial auction.
    Attachment 467300
    Attachment 467302
    Attachment 467304
    It's using PARKER drivers, GALIL DMC-2152 5 axis motion controller and FlexLaser software
    from Assembly Automation Alternatives Inc.
    The mechanical aspect is pretty good and well made but the software is a bit basic and
    I can't do picture engraving (only lines).
    I was able to do some cutting and engraving but since yesterday it seems the laser die...
    The laser is a sealed 120W CO2, model Rofin OEM 10iX 10.6 LP.
    Attachment 467298
    Attachment 467308
    Recently the laser is doing one of those two things:
    - Stays OFF (not turning ON/not cutting nor engraving) during a program and flashing yellow LED on the unit
    - Stays ON, seems to be at full power, all the time even when program not running but not showing any error on the indicator light
    According to the laser manual when flashing yellow it specified VSWR Error (no modulation pulse applied since power up)
    If anyone have any idea what can I verify, check or what could be the source of the problem ?
    If I can't repair the laser, I have the idea of retrofitting with a new motion controller and maybe switching to a cheap CO2 standard tube...
    However, I would like to:
    - keep being able to use the camera for using it with references alignment points
    - using the Z axis table
    - adding a rotary axis system for tube-cylindrical part
    It seems LightBurn software looks nice to work it, I contacted them and they suggested me Ruida controller since over 40W.
    What do you think ?
    AXYZ Millennium router CNC: https://goo.gl/gxvdcA
    Glass cutting CNC table: https://goo.gl/VrDqGD
    Oct 2010
    46
    Re: AL-4824-120-FLX - 120W CO2 - Controller Retrofit and Laser repair ?
    FlexLaser board and motor drivers
    Attachment 467314
    Attachment 467316
    Laser details
    Attached Thumbnails Attached Thumbnails 20210724_144006.jpg   20210724_143957.jpg   20210724_143943.jpg   20210724_143957.jpg
  1. Replies: 3
    Last Post: 08-18-2015, 04:13 AM
  2. Replies: 1
    Last Post: 02-07-2015, 04:31 AM
  3. Replies: 0
    Last Post: 12-15-2014, 04:48 PM
