586,075 active members*
4,112 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Weight in kg of mill along without stand
    Jun 2020
    26
    Hi out there. Can anyone please let me know the weight of the tormach pcnc 1100 without the stand in kg,s please. I have asked tormach two times without an answer. All I am asking for is the weight of the mill alone once removed from its stand. Anyone know. Thanks
    Apr 2013
    1788
    Re: Weight in kg of mill along without stand
    According to https://tormach.com/support/mill/pcn...specifications : 1296 lbs gross (excludes stand) or about 512.5 kg.
    Jun 2006
    3063
    I'd guess that the stand is 250 lbs, making the mill itself around 850 lbs. Just a guess, though. I had the weights of the major components written down at one time but can't find that now.
    FWIW, the column is pinned to the base and the head to the column so it should be possible to break the original PCNC 1100 down into manageable components if you have the desire and aptitude. I broke the mill down into enough pieces that my wife and I could move it from our garage down into our basement. We took our time and it went pretty well. I'd done some alignment and tolerance checks before and after so that I could convince myself that we hadn't screwed up the alignment during the process,
    Jun 2020
    26
    Quote Originally Posted by MichaelHenry View Post
    Hi, thanks for reply. Just got an answer from tormach, the mill it’s self is is 490kg. So you are not far wrong. Michael
