586,416 active members*
3,230 visitors online*
Thread: Clean up.
    Jul 2021
    Clean up.
    Any suggestions on how to clean this up? Way to much to sand.
    Sent from my SM-G781V using Tapatalk
    1230
    Re: Clean up.
    I have used a chisel held vertically to clean up the flat areas at the base of similar relief objects;I used it as a scraper and it worked quite well.For the lettering,I suggest there are two alternatives,one is to go round each letter with a small and very sharp chisel to take away the fuzzy parts.The other is to apply a sealing coat of varnish and then pick out the letters in paint.
    Aug 2005
    205
    Re: Clean up.
    Looks like you're cutting pine? Try a sharp new cutter and cut something like hard maple to see if that makes a difference. Pine can be difficult to cut cleanly.
    Jul 2018
    6385
    Re: Clean up.
    Hi Matt - Is this done in one pass? I've found to do a first pass then a second pass with a slightly deeper cut 0.2mm (finishing pass) helps get rid of the fuzz and use sharp tools. Peter
  1. Cutting not clean
    By Bascil in forum Chinese Machines
    Last Post: 02-02-2018, 12:07 AM
  2. How do I clean this up?
    By KSky in forum BobCad-Cam
    Last Post: 02-22-2015, 06:13 PM
  3. clean up question.....
    By SSN Vet in forum Benchtop Machines
    Last Post: 03-13-2009, 04:36 PM
  4. clean up
    By Claude Boudreau in forum BobCad-Cam
    Last Post: 03-05-2009, 06:54 AM
  5. New X2, what now? How do I clean it.
    By chola in forum Benchtop Machines
    Last Post: 10-01-2008, 11:25 AM
