587,067 active members*
3,724 visitors online*
    Jun 2008
    36
    Part mill size does not match design
    I have been having some issues where my cuts were oversized (for profile cuts) and undersized (for pocket). This is on an Avid 4896 PRO with a 8.5 hp spindle. Material is 3/4" ply. Bit is a 1/4" compression. Other than the size, the cuts looks perfect.
    investigated calibrating the axis motors and made some minor adjustments on step units and backlash, but nothing major. After I had both X and Y dialed in perfectly, I ran tests. I cut two 3x6 in. squares from the same 3.4" ply with the same compression 1/4" endmill I was using before. The pocket test was almost dead on, but the profile result was 3.0325" x 6.0325.
    The only thing I can imagine is that I am doing something wrong in the software. I have tried cuts with both V-carve and Fusion 360 with similar results.
    Any ideas as to next steps to troubleshoot?
    Nov 2006
    1036
    Re: Part mill size does not match design
    Yes!
    I would first r/o a problem with stepper calibration. To do that, I would make objects of several sizes. You mentioned making a 3x6 inch test piece. I would make a 6x12 and even an 12x24 test pieces. If you errors remain .0325 inches, that would tell you that your steppers are properly adjusted.
    to r/o backlash problems, I would approach a line from opposite directions and make cuts. If the lines are offset, then you have a problem with backlash. If the lines are even then you have ruled that out.
    After ruling out above, I would look at software. One common error is to have offsets set incorrectly. Is it possible that you have a .0325 offset set in your profile cuts?
    Jun 2008
    36
    After more reading, and testing, I think a lot of it might to do with machine tolerance / rigidity and my feed speeds. I was running at about 400 ipm for the tests that produced the results above. I dropped the IPM to 50 and saw a significant reduction. I am also going to look at the climb vs conventional cut to see what the deflection is.
    If I find anything exciting, I will post here. Thanks!
    Feb 2006
    992
    I have the same problem but with Mach 3 and I trying to use cutter comp to bring it to size but that is where the machine act funny.
    The best way to learn is trial error.
  1. Pick and Match by radius size selection mask
    By aldepoalo in forum BobCad-Cam
    Last Post: 02-29-2016, 04:24 PM
  2. How to move Mill Stock to match part's 0,0?
    By cismontguy in forum BobCad-Cam
    Last Post: 03-05-2013, 06:58 PM
  3. How do I make CAD/CAM size match machined size?
    By RedCoder in forum Benchtop Machines
    Last Post: 12-07-2010, 11:13 PM
  4. Micro Mill Max part size
    By dneisler in forum Benchtop Machines
    Last Post: 11-09-2005, 03:13 PM
