586,036 active members*
3,392 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Biesse Rover 336 X axis data lost
    Jun 2017
    8
    We have a Biesse Rover 336 that lost a card. After replacing it the machine will home out, but will not run. it throws a code for soft limit switch, so I am assuming we have entered bad data for the Origin and soft limit switches. Can anyone help? I found a thread on here that confirmed the data we have entered for the x axis is accurate, with the exception of the origin and switches. Thanks in advance!
    Jun 2017
    8
    Re: Biesse Rover 336 X axis data lost
    **UPDATE**
    I started guessing with some numbers, and now the machine will move for a simple drilling program. It is dropping in the z axis before it gets into position, then it raises in the z axis before dropping the spindle. It drops agian, but does not make contact with the piece. Any ideas as to what datas need to be adjusted?
    Jun 2017
    8
    ** UPDATE **
    My apologies, The card replaced was for the Z axis, not the X.
    Sep 2018
    Looks to me that the homing point in the machine data has been lost. The Z Axis will need the homing point changing.
    Hope this helps.
    Ant
  1. Biesse Rover 336
    By Sodero in forum Biesse
    Last Post: 12-11-2018, 03:37 PM
  2. Manuals Biesse Rover 336
    By aspan in forum Machinery Manuals / Brochures
    Last Post: 11-30-2015, 09:35 PM
  3. rover 336 data lost
    By freezengate in forum CNC Machining Centers
    Last Post: 11-17-2010, 10:07 PM
