586,096 active members*
3,057 visitors online*
Results 1 to 14 of 14
    Mar 2019
    27
    looking cad/cam software
    I am searching for an easy cad/cam software that can generate ISO G code with 4 axes it could be similar to easycad software or if there a possibility to generate the G-code with the easycad
    Nov 2013
    4375
    Re: looking cad/cam software
    given that Fusion 360 is free to hobbyists/startups it has proven to be popular.
    Craig
    Jun 2015
    4154
    hy, please share a few images, so to have a clue about desired part complexity / kindly
    Apr 2004
    5737
    Take a look at DeskProto. it has several strategies for producing 4-axis G-code from mesh models. It's just a CAM program, though - you can probably make the CAD model in EasyCAD and export it to DeskProto as an STL. https://computersculpture.com/deskproto/
    Andrew Werby
    Website
    Mar 2019
    27
    hiii
    thanks for replying. All I have is an Italian machine for glass with the grinding tool (the 4th axis is in degree) i used to make drawing on mirror glass with a lot of small curves where in some places i need a compensation for the tool.
    if the fusion 360 provide this it will be a great pleasure
    Mar 2019
    27
    all i have a dxf drawing (the 4 axis is in degree) i need to make a compensation for the tool I never heard about deskproto
    Apr 2004
    5737
    What kind of compensation are you talking about?
    Andrew Werby
    Website
    Oct 2016
    10
    Craig
    The free version of Fusion 360 doesn't include 4-axis machining anymore as far as I understand.
    May 2020
    I think you can try the following one
    https://www.vectric.com/products
    Mar 2019
    27
    the compensation of the beginning of the line or arc & the end of it. the grinding tool is like a saw disc just for marking on the glass i have drawing with small arc
    Mar 2019
    27
    this is an example of what i work on it the whole issue is that i will need compensation for the start & the end of the geometry for not having a cross line
    Jun 2015
    4154
    hy tony if you can provide a working code, i can help you with a custom app / kindly
    Mar 2019
    27
    i am using sheetcam but i i have to fix some issue on it i can send u a working code & the post but the issue is a little bit difficult about the threshold of the cutter
    For example if i need to make a square i need on the corner the cutter is to be lifted & compensate the offset of the tool (tool is in the center of geometry) this it can be solved by the value of the threshold but when u have several arcs & in some places should continuous & in other places should be compensate
    this a picture trying to explain my problem the blue marks are the one that it should be connected & the green are the one that should be sompensated
    Jun 2015
    4154
    okey if you wish to discuss specific details, please enable your private messaging, so to avoid flooding the forum
    there should be no problem handling conection between geometries, just like you wish
  1. BobCAD-CAM Releases New v28 CAD-CAM Software Series
    By aldepoalo in forum BobCad-Cam
    Last Post: 07-16-2015, 01:50 AM
  2. Replies: 0
    Last Post: 07-15-2015, 03:08 PM
  3. Which CAD/CAM software
    By dirtridn2010 in forum Mikinimech
    Last Post: 02-08-2011, 01:25 AM
  4. CAD-CAM software
    By dannysdad in forum Uncategorised CAM Discussion
    Last Post: 02-01-2011, 03:35 AM
  5. What CAD/CAM software are you using?
    By marting in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-29-2005, 11:54 PM
