586,062 active members*
4,541 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > SINGLE POINT NPT THREADING ON HAAS LATHE
Results 1 to 10 of 10
    Dec 2009
    5
    I've been working on mills for years and this new job I'm working on lathes as well. I need help with threading a pipe thread. Please don't make fun .
    The tread in question is a 2-1/2 pipe thread about 0.9 inches long.
    G76 is pretty straight forward but if any of you guys knows what is the X value for this specific thread. And also why the said value, where did you picked it up.
    If anyone knows how would this G76 line of command look like?
    When turning for this specific size what is the correct diameter before threading.
    Any nice help and explanations are greatly appreciated
    Dec 2012
    395
    Re: SINGLE POINT NPT THREADING ON HAAS LATHE
    As a European I can give you a Metric example for a Haas ST25Y Next Gen control for a Metric Fine thread M18 x 1.5
    It's a M18 x 1.5 mm pitch with the numbers you can find in a thread table or the Internet.
    Thread height is 0.92mm, so the minor diameter in X = 18 - (2x0.92) = 16.16 mm
    Thread angle is 60 degrees.
    Pitch diameter for your gauge is 17.026 mm
    Haas uses Settings to control your parameters like Chamfer ON/OFF, Chamfer Angle, Minimum cut, Last cut, etc.
    If you want a Chamfer at the end of the thread you have to program M23, if you don't want it M24.
    Setting 95 is Chamfer Size ( multiplied by pitch, max. 1 ) and Setting 96 is Chamfer Angle, these numbers are for M23 - Chamfer ON.
    Setting 99 is Minimum Cut in radius.
    Setting 289 is Finish Allowance in radius / Last Cut.
    Simple would be:
    G00 X25. Z5.
    M23 ( M23 = Chamfer ON or M24 = Chamfer OFF )
    G76 X16.16 Z-20. K0.92 D0.25 A60 F1.5
    X16.16 = minor diameter
    Z-20 = 20mm thread lenght
    K0.92 = height of thread for pitch 1.5mm
    D0.25 = first cut
    A60 = thread angle
    F1.5 = pitch 1.5mm
    Dec 2013
    5717
    For a tapered pipe thread, a G32 might work better. The thread calculations are all done in CAM rather than using the canned cycle on the Haas, but it does add many more lines of code to the program. I use G32 exclusively for all of my single point threading.
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2009
    5
    First I want to thank you for your kind reply. However your reply still doesn't solve my dilemma. I was inquiring about pipe threading. The pipe thread has two diameters and I don't know how to pick my diameter, my X value that I need to put in the G76 line of code. If you know please tell me. Your help if appreciated
    Dec 2009
    5
    Can you please let me know how would a G32 line of code look like for a 2.5 inch pipe thread?
    Dec 2012
    395
    According the Haas manual they use a I - value in the G76 line similar like Fanuc uses a R for tapered thread.
    It's a radial (X) value from start diameter to finish diameter (taper), it's no angle value, there's no example in the book for it.
    This is what the manual says: I - Thread taper amount, radius measure
    If you have the Next Gen control you can make an example for G32 or G76 with VPS, it will create the right code, I don't know for the older control.
    Dec 2009
    5
    I have the manual, read it , understand it. I mean understand every address in the G76 line of command except one in this case.
    G76 X??? Z-1.I-0.086 K0.05 D0.01 F0.088
    This example is just an example, the numbers are not exact for a specific size of external pipe thread.
    The following addresses is what I understand
    G76 threading G code for straight or tapered thread
    Z is final distance in Z axis
    I is the radial difference between the end point and start point of the thread. Negative value for external pipe thread
    K is the radial final depth of cut . Depth of thread
    D is the depth of cut for the first pass
    F is the pitch of the thread.
    What I don't know is the value of X. In this specific case I have to do a 2-1/2 NPT external thread. What is the X value for this thread and where do I pick the value from?
    Mar 2015
    47
    Greetings,
    I Googled Carmex Inserts as I use them in the shop.
    Within the WebPage is an online thread calculator
    .Carmex Tool Wizard - Welcome
    It allows several Controllers for the Post Processing.
    Hopefully, you have gauges to check the final size?
    Cheers,
    Dave
    Feb 2006
    14
    Quote Originally Posted by Nick Doe View Post
    G0 X62.345 Z6.45
    G75 X73.025 Z-35.243 I1300 K2540 D572 A60
    F3.275
    (ISO MM)
    Dec 2009
    5
    Quote Originally Posted by waer View Post
    G0 X62.345 Z6.45
    F3.275
    (ISO MM)
    Servus Waer. Aseara m-am gandit ce faceam gresit. De obicei cand esti aproape de actiune scapi ceva din vedere si asa s-a intamplat si de data asta. Am lucrat pe CNC Mills multi ani si acuma am un nou job unde lucrez freza si strung CNC. Informatia ce am dat-o aici este incompleta. Trebuie sa fac niste " dopuri " care sa inchida gaura ca sa putem sa testam niste piese sub presiune. Dopurile inchid cu garnituri de guma care au locul lor frezat in dop. Informatia incorecta este ca eu de fapt trebuie sa fac un filet incomplet de vreme ce filetul de teava nu se infileteaza pana la capat. Diametrul mare in cazul meu nu poate sa fie diametrul mare normal ci diametrul pana unde cele doua parti se infileteaza. Multumesc pentru ajutor oricum
  1. calculating thread depth (single point lathe threading)
    By QuinnSjoblom in forum MetalWork Discussion
    Last Post: 07-21-2019, 08:42 PM
  2. CNC hobby lathe single point threading
    By ChrisW in forum Uncategorised MetalWorking Machines
    Last Post: 07-08-2013, 09:03 PM
  3. single point NPT threads
    By ianD01 in forum G-Code Programing
    Last Post: 01-10-2012, 02:45 AM
  4. Single point threading (lathe) with EMC
    By chafik in forum LinuxCNC (formerly EMC2)
    Last Post: 06-08-2008, 12:04 AM
  5. Replies: 10
    Last Post: 02-07-2008, 08:28 PM
