586,341 active members*
3,406 visitors online*
    Aug 2021
    Accuracy 300 micron
    Hi!
    I am a hobbyist and i am getting a 1500X2000mm and Z axis down to 100mm CNC router table.
    The spindle is 710W 32K RPM, drivers @ 4.5amp.
    This machine has Accuracy 300 micron, now my question is how good is this accuracy?
    is it worth buying? how many Watt and how many RPM spindle would i need to cutting, carving, and milling trough 8-15mm thick aluminium sheets?
    Aug 2015
    142
    Re: Accuracy 300 micron
    At 300 micron this is good enough for wood .
    Dec 2008
    3111
    300 micron is 0.300mm
    CNC machine for cutting steel, alum, etc for making parts to fit together( depends on purpose ie aerospace parts) would need repeatability of 0.002mm
    Your 300micron machine "might" be OK for making pieces of jigsaw .... just
    If you are using it to play/learn, make artistic jobs & so on... & the price is good. Go for it.
    Alum may need multiple passes, so any passes that are not on top of the last may break tools, leave crappy mismatched finishes.
    Try to look at previous parts, or have it prove itself before purchase.
    Mar 2009
    1982
    Accuracy is really poor even for woodwork. The question is how this accuracy is evaluated. Maybe repeatability is 10× better?
    Spindle power capacity is quite high, so the machine is good for rough work - blanks preparation.
  1. Lathe micron value parameter
    By bdhananjay in forum Turning
    Last Post: 02-17-2021, 03:50 AM
  2. Replies: 0
    Last Post: 02-08-2019, 11:25 PM
  3. MICRON HSM700 Manuels
    By gurayunsal in forum CNC Machining Centers
    Last Post: 01-13-2018, 11:53 PM
  4. 1 micron lathe!!!!!!!!!!!!!!!!!!!!!
    By the4thseal in forum Vertical Mill, Lathe Project Log
    Last Post: 04-26-2016, 03:22 AM
  5. Micron transducers
    By dholzric in forum Servo Motors / Drives
    Last Post: 02-14-2016, 06:50 AM
