586,108 active members*
3,038 visitors online*
    Aug 2009
    119
    Backlash with Lovejoy coupling?
    I removed the stepper on an older Isel slide unit, and discovered there was a bit of backlash in the Lovejoy coupling. Is this is to be expected, or could the spider have shrunk or gotten compressed?
    If it's inherent in the design, thinking to replace with an Oldham coupling. Is there a preferred alternative? It's for a low powered wood router, will use 250 - 350 oz steppers, won't be in a hurry.
    Dec 2013
    5717
    Re: Backlash with Lovejoy coupling?
    I would just replace the spider. They do wear over time. The new ones fit pretty tight.
    Jim Dawson
    Sandy, Oregon, USA
  1. Replies: 18
    Last Post: 08-01-2017, 05:10 AM
  2. couplings - lovejoy vs disc vs zero backlash vs etc ?
    By Jay-D9 in forum Linear and Rotary Motion
    Last Post: 02-21-2017, 10:58 PM
  3. Helical Beam coupling vs "lovejoy" type?
    By phantomcow2 in forum Linear and Rotary Motion
    Last Post: 04-23-2015, 03:38 AM
  4. How does this anti-backlash coupling work?
    By bassman2914 in forum Mechanical Calculations/Engineering Design
    Last Post: 07-26-2011, 08:36 PM
  5. Need to get the right Lovejoy coupling. Can anyone help?
    By alexccmeister in forum Benchtop Machines
    Last Post: 06-09-2007, 02:28 AM
