586,036 active members*
3,493 visitors online*
IndustryArena Forum > MetalWorking Machines > Kitamura > Kitamura HX-250 Coolant Through / Pull Studs
    Apr 2021
    Talking Kitamura HX-250 Coolant Through / Pull Studs
    Looking to see if anyone might have some information on a Kitamura HX-250, BT30 Machine.
    Just got this machine In Service and have a job coming up for it. When getting the machine, it didn't come with manuals.
    Contacted Kitamura USA and they gave me PDF's on the different pull studs.
    On the machine I see a high pressure pump for through coolant, but I don't know the M command to Turn it on.
    Haven't bought holders or studs yet, incase I'm just being an idiot.
    So my question(s) is What M command turns on through spindle coolant. Also if someone else has one of these machines, are the BT30 Tool holders single contact?
    Thanks in Advance,
    Rich
    Edit: Yasnac I-80 M controller
    Apr 2021
    Re: Kitamura HX-250 Coolant Through / Pull Studs
    So I think it's M7, because I get the air blow after it turns off and it looks that the pump is turning on. No coolant thou. I'm thinking the inlet it clogged. I'll take a look at it tomorrow
  1. Pull studs
    By Scrambled1 in forum HURCO
    Last Post: 11-20-2016, 08:19 PM
  2. Which CAT 40 pull studs?
    By sortafast in forum Uncategorised MetalWorking Machines
    Last Post: 08-03-2013, 05:28 PM
  3. What pull studs
    By zcases in forum Fadal
    Last Post: 11-03-2012, 10:54 PM
  4. pull studs
    By najnielkp in forum Uncategorised MetalWorking Machines
    Last Post: 06-12-2009, 02:42 AM
