586,043 active members*
3,687 visitors online*
    Unhappy Need Help with a swiss lathe
    Hello, I need help with a Swiss Nomura NN-13bs, and I would appreciated if someone can help me with this issue. I can't find the way to make the swiss touch up the X and Z axis? if anyone had or have work on this type of machine and can help me I really appreciated.
    Oct 2016
    8
    Re: Need Help with a swiss lathe
    You may already have your answer but the Nomura Swiss machines use an optical tool setter to set the turning tools in the removable holders prior to mounting on the machine. It is great for changing inserts but is difficult to set if you do not have the optical setter since the tools need to be set for X, Y, and Z position prior to mounting. The end working tools are set in Z only using a U shaped gage supplied by Nomura for the front side and you simply touch off the piece to the tool on the back side and enter the Z value in the Tool Offsets page. Best of luck
  1. swiss lathe tooling help
    By reddog37 in forum Uncategorised MetalWorking Machines
    Last Post: 04-29-2015, 07:43 AM
  2. Swiss Lathe help in Midwest
    By montie in forum CNC Swiss Screw Machines
    Last Post: 11-03-2011, 05:27 PM
  3. lathe and swiss needs in SE USA
    By BILL WRIGHT CCR in forum Employment Opportunity
    Last Post: 10-06-2011, 01:37 AM
  4. Looking for a used swiss lathe
    By Dennis Dellinge in forum Want To Buy...Need help!
    Last Post: 05-14-2008, 12:04 PM
  5. Swiss lathe
    By Captain Midnigh in forum Want To Buy...Need help!
    Last Post: 05-14-2008, 07:32 AM
