586,785 active members*
2,908 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Upgrading to cmos memory from bubble memory osp5000
    May 2011
    20
    I just installed a cmos card to replace the bubble memory in our lb15 with osp5000 control.
    Im trying to reload the control tapes but the tape keeps stopping and it doesn't produce any errors.
    Is there anything different that i need to do to reload the control tapes to the cmos memory?
    Mar 2007
    84
    Re: Upgrading to cmos memory from bubble memory osp5000
    If I remember correctly there was something about entering (in load screen) info about ffrom where software is loaded (tape or floppy). It was either on one of those many manuals on some upgrade bulletins.
    What year is that lathe? CMOS boards work with new MBIIB motherboards. Another case i have stumbled upon was software- on my milling machine (MC-4VA) only newer version of software was able to load and run, original from 1984 was unable to run.
    May 2011
    20
    I managed to get it working. The batteries were flat on the cmos card. Ill put new ones on and still didn't work. I then removed all the jumpers on the card and it loaded the control software exactly the same as it used to with the bubble memory. The machine kept corrupting the bubble memory and it was getting read/write errors. Been running fine now for 3 days with the cmos card.
  1. CMOS memory for OSP5000, 2135 error code
    By GuntisK in forum Okuma
    Last Post: 06-27-2021, 04:54 PM
  2. Bubble memory
    By Dancy in forum Hitachi Seikis
    Last Post: 05-31-2019, 04:57 PM
  3. bubble memory gone
    By JCVineyard in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-15-2011, 04:51 PM
  4. Bubble Memory
    By handasee in forum CNC Machine Related Electronics
    Last Post: 03-19-2010, 02:18 AM
  5. Bubble memory
    By Darkos in forum Fanuc
    Last Post: 06-06-2006, 09:29 PM
