586,047 active members*
3,720 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > 1994 haas vf2 alarm 123 spindle drive fault
    I have a 1994 haas vf2 that I am having some troubles with, when I try to home the machine, or turn the spindle on I get a 123 alarm, I check the alarm on the vfd and the manual says it's an over current on acceleration, I should also note that I will occasionally get a spindle orientation alarm while trying to do a tool change any help would be great. TIA
    Jun 2013
    Re: 1994 haas vf2 alarm 123 spindle drive fault
    What error code is the drive giving?
    https://www.haascnc.com/service/trou...ing-guide.html
    regards,
    Mark
  1. Alarm # 123 Spindle Drive Fault
    By Web.eng in forum Haas Mills
    Last Post: 02-05-2020, 07:33 PM
  2. 123 Spindle Alarm Fault Haas
    By wisrepairs in forum Haas Mills
    Last Post: 04-29-2018, 03:45 AM
  3. 1992 VF2 Alarm 123 spindle Spindle Drive Fault
    By dafowfidy in forum Haas Mills
    Last Post: 05-14-2012, 07:32 PM
  4. Haas 123 Spindle Drive Fault question
    By mikshaw in forum Haas Mills
    Last Post: 05-06-2009, 03:31 AM
  5. Alarm 123 Spindle Drive Fault
    By Shotout in forum Haas Mills
    Last Post: 05-27-2007, 05:48 PM
