586,609 active members*
3,589 visitors online*
    Oct 2013
    34
    NC/PLC no connection
    Hey!
    We have a problem with the NC/PLC not getting a connection when we restart the machine it says that the system might be corrupt.
    when checking diagnos in the machine it says communication fault repeat the process. If the error is still there do a "NCK" Power on Restet.
    IF the error is still continue the turn off and then on MMC and NCK.
    what is the MMC and NCK?
    Jan 2018
    1516
    Re: NC/PLC no connection
    Quote Originally Posted by swealf View Post
    Hey!
    First things that came up in a search were:
    MMC = Micro Memory Card
    and
    https://www.practicalmachinist.com/v...reload-254517/
    https://www.manualslib.com/manual/15...?page=5#manual
    https://support.industry.siemens.com...=0&pageSize=10
    I know nothing of Siemens so you need to do some research.
    15362
    Hey!
    This may help has anyone changed any Parameters
    Mactec54
  1. Alarm PLC 261 and PLC 431 of waterjet cut
    By Hanif95 in forum Waterjet General Topics
    Last Post: 11-16-2018, 09:06 AM
  2. SIEMENS 810 PLC error, need PLC files
    By =aike= in forum SIEMENS -> Sinumerik 810M/810T
    Last Post: 06-26-2017, 08:03 PM
  3. Arcing connection on Laser CO2 tube connection
    By pcaulfie in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 11-06-2015, 07:00 PM
  4. Replies: 4
    Last Post: 09-17-2013, 07:15 PM
  5. Connection with Humidity sensor (4-20ma) and PLC or temperature controller
    By rainman in forum CNC Machine Related Electronics
    Last Post: 09-13-2008, 12:55 AM
