586,068 active members*
3,659 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas TM 1P List program Failure
    Jul 2021
    Part of my work is running parts on a TM 1P mill that has a frustrating quirk. For some reason, while the machine is running it won't allow access to the "list program" functions. When List Program is pressed it responds with "Not available while Running" I've been told by my local HAAS dealer that this shouldn't be happening, that I should be able to access and load programs to and from the machine so long as I'm not trying to change the active program. But here we are and it won't allow access. Anyone ever run into this? Is there a setting buried somewhere that I need to toggle?
    Aug 2009
    1573
    Re: Haas TM 1P List program Failure
    ...is this what you're looking for?
    https://staging-diy.haascnc.com/background-edit-0
  1. Haas TL2 X diameter measure oddity
    By Machoot in forum Haas Lathes
    Last Post: 01-26-2022, 01:16 PM
  2. List of Haas G codes?
    By rawen2 in forum Haas Mills
    Last Post: 10-29-2012, 03:37 AM
  3. List of program names and #'s
    By daking in forum Fadal
    Last Post: 01-17-2006, 04:39 AM
  4. Haas parts list
    By rattlesnake363 in forum Haas Mills
    Last Post: 08-11-2005, 03:38 AM
