586,121 active members*
2,985 visitors online*
    Aug 2021
    4
    Zero Reference Return Problem.
    Hello,
    I have a Hardinge SV200 CNC Lathe equipped with a Fanuc SV control. I have six months using this machine without a problem until yesterday. I notice that when I was running a program, all of a sudden the machine added or substracted 0.394" randomly on the Z axis. I started doing some testing and notice that every time I did the zero reference return, the machine stopped in a 0.0001 coordinate or in a 0.394 coordinate. This way it didn't matter how often I adjust my Z tool offset, this kept changing randomly. I don't know how to fix it and I would definetly appreciate any help.
    Aug 2021
    4
    Re: Zero Reference Return Problem.
    Update: I was able to fix it. Luckily I had an extra limit switch for the Z axis, I change it and problem solved. Still, here is a link to a video showing the problem I was having. https://youtu.be/z6bhRklaYZM
    I hope this helps someone else.
  1. Fanuc Zero Reference Return Problems?
    By grege101 in forum Fanuc
    Last Post: 09-19-2023, 12:52 PM
  2. Fanuc 6m Manual reference return
    By Lomach in forum Fanuc
    Last Post: 08-28-2017, 01:15 AM
  3. Reference return incomplete
    By Leha_Blin in forum Fanuc
    Last Post: 08-17-2011, 04:22 AM
  4. G30(reference point return)
    By Reg wharton in forum Daewoo/Doosan
    Last Post: 06-13-2008, 11:32 AM
  5. Return through reference point?
    By RBrandes in forum Haas Mills
    Last Post: 12-02-2005, 04:49 PM
