586,270 active members*
4,143 visitors online*
    Nov 2015
    260
    Problems whit the error pin.
    New motor drivers, new problems with the alarm signal / error pin.
    Hello.
    I have four drivers on my MK3 / 9 controller.
    I use the ALM signals. With the old drivers everything was as it should.
    When a motor went into alarm, the EStop was activated.
    Now with the new drivers, the CL57Y only works as long as no more than two drivers are connected.
    I also tried "Normally Closed", but the ALM signal from the driver is ignored by the error pin.
    I've tested all drivers, I've checked all cables. I checked the driver settings several times and also changed them to test.
    So alo my question, what am I doing wrong.
    Mar 2017
    1312
    Re: Problems whit the error pin.
    How are alarm signals connected? My guess is that you connected open collector signal in parallel.
    Nov 2015
    260
    I've tried both variants. I have now switched to NC and optocoupler. Now it works.
  1. One thing I don't understand about the error pin.
    By tantemay in forum PlanetCNC
    Last Post: 02-04-2021, 01:08 PM
  2. Replies: 11
    Last Post: 01-14-2020, 11:59 AM
  3. error: Extruder.hal:87: parameter or pin 'stepgen.6.position-scale' not found
    By Tim Groenewald in forum LinuxCNC (formerly EMC2)
    Last Post: 05-16-2013, 04:17 PM
  4. Problems whit angular head
    By Bjarne_m in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-11-2009, 09:16 AM
  5. Problems whit feeds and Speeds
    By jensen in forum BobCad-Cam
    Last Post: 10-18-2008, 05:09 AM
