586,589 active members*
2,528 visitors online*
IndustryArena Forum > MetalWorking Machines > Shopmaster/Shoptask > 2018 Mill Turn Configuration for Fusion 360
    Jan 2010
    17
    What kind of configuration are you using for Fusion 360? Do you need to set one up for each function (mill and lathe) or did you set up a separate one for each? Just wanted to get your thoughts. Thanks,
    jdub
    Dec 2013
    5717
    Re: 2018 Mill Turn Configuration for Fusion 360
    You can do it all in one setup. There is an option to set the tool orientation. I run a couple of parts that have turned, milled, and cross drilled features and do it in one setup. I use the Haas ST35Y post processor. One note, if drilling with the spindle, be sure to uncheck the Live Tool box in the Tool>Post Processor setup or it will try to use the live tool.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2010
    17
    Jim, Thanks for the quick response. What control software are you using on the Mill-Turn? I've updated my machine to Centroid's Acorn, so I was planning on using that for the post processor, but it looks like Fusion has one for turning and one for milling. Do you think the Haas post processor would work?
    Dec 2013
    5717
    Quote Originally Posted by jdub63 View Post
    I wrote my own control software, and I wrote the G code translator to be compatible with the Haas posts.
    The Haas posts are pretty generic, so you might try using that for the Acorn system and see what happens. Run some air cuts to make sure your machine is going to behave.
    The other thing you can do is to just manually merge the G code from separate operations. I guess the other thing to concider is how the machine axes are assigned. In other words, is your machine a lathe with live tooling and a Y and C axis in a standard configuration? That's what the Haas ST35Y post assumes. You can turn off the Y axis in the post configuration if not used, that's what I do.
    Jim Dawson
    Sandy, Oregon, USA
  1. Mill Turning with Fusion 360
    By gunmaker in forum Milltronics
    Last Post: 04-01-2024, 09:21 PM
  2. Fusion 360 for mill turn mazak lathe.
    By tspiszak in forum Autodesk Post Processors
    Last Post: 07-29-2022, 04:27 PM
  3. Fusion 360 Postprocessor for DM1007 mill
    By Sun God in forum Dyna Mechtronics
    Last Post: 03-29-2021, 12:12 PM
  4. Modified Fusion 360 Post for the Tormach Rapid Turn
    By mattford1 in forum Tormach Personal CNC Mill
    Last Post: 04-26-2017, 01:00 AM
