586,117 active members*
3,510 visitors online*
Page 2 of 2 12
Results 21 to 22 of 22
  1. #21
    Jul 2018
    6341
    Re: Cnc router electronics
    Hi GoCe - Use proper round cars and matching round rail. Not commercial tubing, Won't work. Linear rail is hardened and ground to a specification. The car balls will gall the unhardened steel or aluminium tube. Peter
  2. #22
    Jun 2010
    4256
    what you think about SBR16UU linear bearing block on steel/aluminum tubing, can it work??
    Of course it will 'work'.
    Those hardened steel balls will work lovely grooves into the soft steel or aluminium tubes. After the first couple of passes there will be no more drag at all. Could be a little slop and rattle of course.
    Cheers
    Roger
    PS: the above 'approval' is not meant to be taken seriously.
Page 2 of 2 12
  1. Need help with electronics for cnc router
    By willja67 in forum Want To Buy...Need help!
    Last Post: 08-27-2021, 09:17 PM
  2. CNC Router Electronics
    By jimmyzwoodworks in forum Controller Cards
    Last Post: 07-01-2020, 09:21 AM
  3. CNC Router Electronics?
    By wmacdonald250 in forum CNC Machine Related Electronics
    Last Post: 03-30-2017, 11:53 PM
  4. CNC router electronics recommendation.
    By georges12 in forum Stepper Motors / Drives
    Last Post: 07-24-2015, 01:10 AM
