586,061 active members*
4,379 visitors online*
    Aug 2021
    To CO2 laser experts
    Hello,
    I'd like some advise on weather a damaged CO2 laser is usable / repairable.
    I've just started a DIY CO2 laser cutting build. I've had some trouble getting a laser tube delivered to my house in one piece. I bought a laser / PSU (80W) set on Ebay and they sent a tube, which upon inspection, has the glass connection to the high voltage supply snapped off. I've attached an image to give you some idea of the degree of damage.
    The EBay seller was great and gave me a refund and allowed me to keep the working (i hope) PSU and damaged laser. I'm not too familiar with how these things work and exactly what damage would make them inoperable, and what damage could be repaired. My key concerns are:
    1) That CO2 is required in the void that's now exposed to the atmosphere (would have leaked out). Am I right in saying that the CO2 is confined to the inner-most tube c. 10mm diameter?
    2) I've not glued glass back together before. I'm thinking epoxy, any better ideas?
    3) That repairing this could cause some safety issues that i'm not considering. After Epoxy and eleventy rolls of insulating tape around the connection and surrounding region, do I have cause for concern?
    Appreciative of all advise.
    Best,
    Luke
    Nov 2008
    643
    Re: To CO2 laser experts
    Most likely the tube is junk. Every CO2 tube consists of an inner tube with power connections and gas. Then an outer jacket where the water circulates. So your mixing water and high voltage and placing the tube in a metal box not designed to see water.
    Assuming the outer jacket water side is all thats damaged, is it worth taking the chance it will spring a leak at some point. It’s complete junk if the inner tube is damaged. Tubes aren’t that expensive.
    Aug 2005
    108
    If the tube came with broke IN or OUT water glass pipe it is easy to fix with UV adhesive or even epoxy, but in your case no way, u can use as decorative in your workshop.
    Oct 2021
    buy a RECI tube & move on.
    Aug 2021
    17
    If your CO2 laser Beam contour is not sealed now and lost all CO2 - than your tube is junk now.
    If it have only damaged HV mounting pad - use good high temperature epoxy without metal.
  1. CO2 Laser Mark-Help CO2 laser machine engraving metal
    By CO2LaserMark in forum Commercial Laser
    Last Post: 04-11-2017, 05:48 AM
  2. 40W co2 laser engraving cutting machine engraver cutter cnc CO2 Laser Engraver Cutter
    By ecpur in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-27-2015, 08:23 AM
  3. Laser tube and power supply 40W co2 and 60w co2
    By Yaro in forum RFQ (Request for Quote)
    Last Post: 07-18-2014, 08:36 AM
  4. Reusable CO2 100W 130W 150W Laser Tube ? Replace the traditional CO2 laser tube
    By dianmanlaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-03-2013, 05:04 AM
